论坛/开源蜂鸟E203/n101移植非官方FPGA开发板,二线JTAG调试openocd连不上JTAG
开源蜂鸟E203 作者 发布于 2022-03-03 13:20(1722 天前) 23301 浏览
移植n101软核到非官方指定的FPGA板卡中(XC7A100TFGG676-1),蜂鸟调试器连接JTAG接口(二线JTAG调试),在使用openocd连接JTAG时,发现有报错,如下所示:
D:\OpenOCD\bin>openocd -f openocd_hbird.cfg
Open On-Chip Debugger 0.11.0 (2021-11-18) [https://github.com/sysprogs/openocd]
Licensed under GNU GPL v2
libusb1 09e75e98b4d9ea7909e8837b7a3f00dda4589dc3
For bug reports, read
DEPRECATED! use ‘adapter speed’ not ‘adapter_khz’
DEPRECATED! use ‘adapter driver’ not ‘interface’
DEPRECATED! use ‘ftdi vid_pid’ not ‘ftdi_vid_pid’
DEPRECATED! use ‘ftdi layout_init’ not ‘ftdi_layout_init’
DEPRECATED! use ‘ftdi layout_signal’ not ‘ftdi_layout_signal’
Info : auto-selecting first available session transport “jtag”. To override use ‘transport select ‘.
Info : clock speed 1000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway…
Error: riscv.cpu: IR capture error; saw 0x1f not 0x01
Error: Unsupported DTM version: 15
接口连线正确,有人遇到过这种情况吗?应该怎么解决?多谢!!!!
全部回复 21
富
富贵花开814 天前 · 1 楼
回复 匿名用户:
还是报错,但是和前几次的不一样,如下:
Open On-Chip Debugger 0.11.0+dev-01889-geee887d60 (2022-01-13-23:33)
DEPRECATED! use 'adapter speed' not 'adapter_khz'
DEPRECATED! use 'adapter driver' not 'interface'
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
Info : Using libusb driver
Info : hbird_debugger: This TAP's version is too old, trying use async sequence to handshake..
Info : JTAG tap: riscv.cpu tap/device found: 0x82000211 (mfg: 0x108 (Ardent Technologies), part: 0x2000, ver: 0x8)
Info : TAP auto0.tap does not have valid IDCODE (idcode=0x2494aa94)
Info : TAP auto1.tap does not have valid IDCODE (idcode=0x924a554a)
Info : JTAG tap: auto2.tap tap/device found: 0x49252aa5 (mfg: 0x552 (NOR-MEM), part: 0x9252, ver: 0x4)
Info : TAP auto3.tap does not have valid IDCODE (idcode=0x25249124)
Info : TAP auto4.tap does not have valid IDCODE (idcode=0x92924892)
Info : JTAG tap: auto5.tap tap/device found: 0x49492449 (mfg: 0x224 (Raza Microelectronics), part: 0x9492, ver: 0x4)
Info : TAP auto6.tap does not have valid IDCODE (idcode=0x92492492)
Info : JTAG tap: auto7.tap tap/device found: 0x49249249 (mfg: 0x124 (Peregrine Semiconductor), part: 0x9249, ver: 0x4)
Info : TAP auto8.tap does not have valid IDCODE (idcode=0x92492492)
Info : JTAG tap: auto9.tap tap/device found: 0x49249249 (mfg: 0x124 (Peregrine Semiconductor), part: 0x9249, ver: 0x4)
Info : TAP auto10.tap does not have valid IDCODE (idcode=0x92492492)
Info : JTAG tap: auto11.tap tap/device found: 0x49249249 (mfg: 0x124 (Peregrine Semiconductor), part: 0x9249, ver: 0x4)
Info : TAP auto12.tap does not have valid IDCODE (idcode=0x92492492)
Info : JTAG tap: auto13.tap tap/device found: 0x49249249 (mfg: 0x124 (Peregrine Semiconductor), part: 0x9249, ver: 0x4)
Info : TAP auto14.tap does not have valid IDCODE (idcode=0x92492492)
Info : JTAG tap: auto15.tap tap/device found: 0x49249249 (mfg: 0x124 (Peregrine Semiconductor), part: 0x9249, ver: 0x4)
Info : TAP auto16.tap does not have valid IDCODE (idcode=0x92492492)
Info : JTAG tap: auto17.tap tap/device found: 0x49249249 (mfg: 0x124 (Peregrine Semiconductor), part: 0x9249, ver: 0x4)
Info : TAP auto18.tap does not have valid IDCODE (idcode=0x92492492)
Info : JTAG tap: auto19.tap tap/device found: 0x49249249 (mfg: 0x124 (Peregrine Semiconductor), part: 0x9249, ver: 0x4)
Warn : Unexpected idcode after end of chain: 331 0x92492492
Warn : Unexpected idcode after end of chain: 363 0x24924924
Warn : Unexpected idcode after end of chain: 395 0x49249249
Warn : Unexpected idcode after end of chain: 427 0x92492492
Warn : Unexpected idcode after end of chain: 459 0x24924924
Warn : Unexpected idcode after end of chain: 491 0x49249249
Warn : Unexpected idcode after end of chain: 523 0x92492492
Warn : Unexpected idcode after end of chain: 555 0x24924924
Warn : Unexpected idcode after end of chain: 587 0x49249249
Warn : Unexpected idcode after end of chain: 619 0x92492492
Error: double-check your JTAG setup (interface, speed, ...)
Error: Trying to use configured scan chain anyway...
Warn : AUTO auto0.tap - use "jtag newtap auto0 tap -irlen 2 -expected-id 0x00000000"
Error: auto0.tap: IR capture error; saw 0x0000 not 0x0001
Error: dtmcontrol is 0. Check JTAG connectivity/board power.
您好,请问这个问题解决了吗,是怎么解决的。
小佳
小佳1228 天前 · 2 楼
回复 匿名用户:
使用的就是V2,Debugger Kit V2
请问这个V2和V1版本的主要区别是,FTDI芯片的型号不同么?
1721 天前 · 3 楼
  “assign jtag_TMS=jtag_DRV_TMS?jtag_TMS_out:1'bz;
    assign jtag_TMS_in=jtag_TMS;”
这个地方TMS信号的处理,参考原N101的工程来改一下吧,用IOBUF来处理,在约束里面带上KEEP属性。
又报这样的错了:
胡灿1721 天前 · 4 楼
1721 天前 · 5 楼
回复 匿名用户:
还是报错,但是和前几次的不一样,如下:
cfg配置文件如下:
adapter_khz 1000
interface ftdi
#ftdi_device_desc "USB <-> JTAG-DEBUGGER"
ftdi_vid_pid 0x0403 0x6010
ftdi_oscan1_mode on
ftdi_layout_init 0x0008 0x001b
ftdi_layout_signal nSRST -oe 0x0020 -data 0x0020
ftdi_layout_signal TCK -data 0x0001
ftdi_layout_signal TDI -data 0x0002
ftdi_layout_signal TDO -input 0x0004
ftdi_layout_signal TMS -data 0x0008
ftdi_layout_signal JTAG_SEL -data 0x0100 -oe 0x0100
#Reset Stretcher logic on FE310 is ~1 second long
#This doesn't apply if you use
# ftdi_set_signal, but still good to document
#adapter_nsrst_delay 1500
set _CHIPNAME riscv
jtag newtap $_CHIPNAME cpu -irlen 5
set _TARGETNAME $_CHIPNAME.cpu
target create $_TARGETNAME riscv -chain-position $_TARGETNAME
$_TARGETNAME configure -work-area-phys 0x80000 -work-area-size 10000 -work-area-backup 1
init
#reset
if {[ info exists pulse_srst]} {
  ftdi_set_signal nSRST 0
  ftdi_set_signal nSRST z
halt
1722 天前 · 6 楼
约束里面加上这个吧
set_property KEEPER true [get_ports  jtag_TMS]
还是报错,但是和前几次的不一样,如下:
胡灿1722 天前 · 7 楼
回复 匿名用户:
约束:
# 时钟引脚
set_property IOSTANDARD LVCMOS33 [get_ports clk50mhz]
set_property PACKAGE_PIN U22 [get_ports clk50mhz]
# 复位引脚
set_property IOSTANDARD LVCMOS33 [get_ports rst_n]
set_property PACKAGE_PIN AC26 [get_ports rst_n]
set_property IOSTANDARD LVCMOS33 [get_ports jtag_rst]
set_property PACKAGE_PIN P4 [get_ports jtag_rst]
# JTAG TCK引脚
set_property IOSTANDARD LVCMOS33 [get_ports jtag_TCK]
set_property PACKAGE_PIN E26 [get_ports jtag_TCK]
set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets jtag_TCK]
# JTAG TMS引脚
set_property IOSTANDARD LVCMOS33 [get_ports jtag_TMS]
set_property PACKAGE_PIN E25 [get_ports jtag_TMS]
#串口tx
set_property IOSTANDARD LVCMOS33 [get_ports tx_evt]
set_property PACKAGE_PIN G22 [get_ports tx_evt]
#串口rx
set_property IOSTANDARD LVCMOS33 [get_ports rx_evt]
set_property PACKAGE_PIN J25 [get_ports rx_evt]
顶层TOP:
module n101_core_100T_top(
  input jtag_TCK,
  inout jtag_TMS,
  //input jtag_TDI,
  output jtag_dwen,
  output tx_evt,
  input rx_evt,
  //input i_dbg_stop,
  input jtag_rst,
  input clk50mhz,
  input rst_n
    //wire jtag_TDI_IN;
    wire jtag_TMS_out;
    wire jtag_DRV_TMS;
    wire jtag_TMS_in;
    //assign jtag_TDI_IN=jtag_TDI;
  n101_core_wrapper n101_core_wrapper(
                       .jtag_TCK(jtag_TCK),
                       .jtag_TMS_in(jtag_TMS_in),
                       .jtag_TDI(),
                       .jtag_TDO(),
                       .jtag_DRV_TDO(),
                       .jtag_dwen(jtag_dwen),
                       .jtag_TMS_out(jtag_TMS_out),
                       .jtag_DRV_TMS(jtag_DRV_TMS),
                       .jtag_BK_TMS(),
                       .hart_halted(),
                       .i_dbg_stop(1'b0),
                       .sysrstreq(),
                       .core_clk_aon(clk50mhz),
                       .core_clk(clk50mhz),
                       .core_reset_n(rst_n),
                       .por_reset_n(jtag_rst),
                       .reset_bypass(1'b0),
                       .clkgate_bypass(1'b1),
                       .mtime_toggle_a(1'b1),
                       .dbg_toggle_a(1'b1),
                       .clic_irq(2'b00),
                       .htrans(),
                       .hwrite(),
                       .hsize(),
                       .hburst(),
                       .hmastlock(),
                       .hwdata(),
                       .hprot(),
                       .master(),
                       .hrdata(32'd0),
                       .hresp(2'b00),
                       .hready(1'b1),
                       .tx_evt(tx_evt),
                       .rx_evt(rx_evt),
                       .core_wfi_mode(),
                       .hart_id(32'h0),
                       .reset_vector(20'd0),
                       .core_sleep_value()
endmodule
约束里面加上这个吧
1722 天前 · 8 楼
回复 匿名用户:
约束:
# 时钟引脚
# 复位引脚
# JTAG TCK引脚
# JTAG TMS引脚
#串口tx
#串口rx
顶层TOP:
  input jtag_TCK,
  inout jtag_TMS,
  //input jtag_TDI,
  output jtag_dwen,
  output tx_evt,
  input rx_evt,
  //input i_dbg_stop,
  input jtag_rst,
  input clk50mhz,
  input rst_n
    //wire jtag_TDI_IN;
    wire jtag_TMS_out;
    wire jtag_DRV_TMS;
    wire jtag_TMS_in;
                       .jtag_TDI(),
                       .jtag_TDO(),
                       .jtag_DRV_TDO(),
                       .jtag_BK_TMS(),
                       .hart_halted(),
                       .i_dbg_stop(1'b0),
                       .sysrstreq(),
                       .clic_irq(2'b00),
                       .htrans(),
                       .hwrite(),
                       .hsize(),
                       .hburst(),
                       .hmastlock(),
                       .hwdata(),
                       .hprot(),
                       .master(),
                       .hrdata(32'd0),
                       .hresp(2'b00),
                       .hready(1'b1),
                       .tx_evt(tx_evt),
                       .rx_evt(rx_evt),
                       .core_wfi_mode(),
                       .hart_id(32'h0),
                       .core_sleep_value()
endmodule
jtag_rst直接约束位FPGA板上的复位按键,蜂鸟调试器上的rst管脚是悬空的
1722 天前 · 9 楼
JTAG的约束也发出来看看吧
约束:
# 时钟引脚
# 复位引脚
# JTAG TCK引脚
# JTAG TMS引脚
#串口tx
#串口rx
顶层TOP:
  input jtag_TCK,
  inout jtag_TMS,
  //input jtag_TDI,
  output jtag_dwen,
  output tx_evt,
  input rx_evt,
  //input i_dbg_stop,
  input jtag_rst,
  input clk50mhz,
  input rst_n
    //wire jtag_TDI_IN;
    wire jtag_TMS_out;
    wire jtag_DRV_TMS;
    wire jtag_TMS_in;
                       .jtag_TDI(),
                       .jtag_TDO(),
                       .jtag_DRV_TDO(),
                       .jtag_BK_TMS(),
                       .hart_halted(),
                       .i_dbg_stop(1'b0),
                       .sysrstreq(),
                       .clic_irq(2'b00),
                       .htrans(),
                       .hwrite(),
                       .hsize(),
                       .hburst(),
                       .hmastlock(),
                       .hwdata(),
                       .hprot(),
                       .master(),
                       .hrdata(32'd0),
                       .hresp(2'b00),
                       .hready(1'b1),
                       .tx_evt(tx_evt),
                       .rx_evt(rx_evt),
                       .core_wfi_mode(),
                       .hart_id(32'h0),
                       .core_sleep_value()
endmodule
1722 天前 · 10 楼
那连线是如何连的呢
TMS和TCK分别使用杜邦线手工连接FPGA板上对应的约束好的管脚,vcc3v3接板卡上3.3v管脚,GND接地
胡灿1722 天前 · 11 楼
JTAG的约束也发出来看看吧
胡灿1722 天前 · 12 楼
回复 匿名用户:
改了,还是报相同的错,如下:
Error: JTAG scan chain interrogation failed: all zeroes
Error: riscv.cpu: IR capture error; saw 0x00 not 0x01
那连线是如何连的呢
1722 天前 · 13 楼
回复 匿名用户:
改了,还是报相同的错,如下:
看错了,不是报all ones了,而是报 all zeros
1722 天前 · 14 楼
看了下配置文件,还有个地方对应改成如下
改了,还是报相同的错,如下:
胡灿1722 天前 · 15 楼
回复 匿名用户:
四线没有问题
看了下配置文件,还有个地方对应改成如下
