用Nexys A7 100t板子Nuclei Studio连不上设备的问题
我使用的板子是Artix A7100t的板子,安装了蜂鸟的驱动和FTDI的驱动之后,在Nuclei Studio上run helloworld程序的时候出现如下报错:
确保四线接了而且配置没问题,UART0也接了
设备管理器如下:
我按照博客的教程改了cfg文件,有关flash的三行注释掉了
adapter_khz 1000
interface ftdi
ftdi_vid_pid 0x0403 0x6010
ftdi_oscan1_mode off
transport select jtag
ftdi_layout_init 0x0008 0x001b
ftdi_layout_signal nSRST -oe 0x0020 -data 0x0020
ftdi_layout_signal TCK -data 0x0001
ftdi_layout_signal TDI -data 0x0002
ftdi_layout_signal TDO -input 0x0004
ftdi_layout_signal TMS -data 0x0008
ftdi_layout_signal JTAG_SEL -data 0x0100 -oe 0x0100
set _CHIPNAME riscv
jtag newtap $_CHIPNAME cpu -irlen 5
set _TARGETNAME $_CHIPNAME.cpu
target create $_TARGETNAME riscv -chain-position $_TARGETNAME
$_TARGETNAME configure -work-area-phys 0x80000000 -work-area-size 10000 -work-area-backup 1
# set _FLASHNAME $_CHIPNAME.flash
# flash bank $_FLASHNAME fespi 0x20000000 0 0 0 $_TARGETNAME
# Set the ILM space also as flash, to make sure it can be add breakpoint with hardware trigger
#flash bank onboard_ilm fespi 0x80000000 0 0 0 $_TARGETNAME
# Expose Nuclei self-defined CSRS range 770-800,835-850,1984-2032,2064-2070
# See https://github.com/riscv/riscv-gnu-toolchain/issues/319#issuecomment-358397306
# Then user can view the csr register value in gdb using: info reg csr775 for CSR MTVT(0x307)
riscv expose_csrs 770-800,835-850,1984-2032,2064-2070
init
#reset
if {[ info exists pulse_srst]} {
ftdi_set_signal nSRST 0
ftdi_set_signal nSRST z
halt
# We must turn on this because otherwise the IDE version debug cannot download the program into flash
# flash protect 0 0 last off
run configuration设置如下:
q
qfy66661373 天前 ·
1 楼
新百胜公司注册《w ww.xbs3336.com》负责人电话《17649222126》网纸 www.xbs6666.cc 加微
《qfy668809》正规实体三合一娱乐,公司秉承公平,公正,公开为宗旨,联合出品免责声明:本文来
自腾讯新闻客户端自媒体,该文观点仅代表作者本人,搜狐号、网易号、企鹅号、百家号系信息发布平台,
本平台仅提供信息存储服来源:央视网、人民网、搜狐财经、新华网、凤凰资讯、网易新闻、知乎日报、
热点资讯、搜狐新闻、新浪新闻总策划:莫言!
回复2
浏览5992
发布2022-04-15 19:06
