论坛/开源蜂鸟E203/[求助]非官方FPGA开发板,四线JTAG下载程序失败,请问如何解决?
开源蜂鸟E203 作者 MicrooGRIT 发布于 2023-02-12 14:41(1376 天前) 7894 浏览
开发板:正点原子达芬奇Pro开发板FPGA Artix-7 XC7A100T
调试器:Sipeed USB-JTAG/TTL RISC-V调试器
OpenOCD报错如下:
Open On-Chip Debugger 0.11.0+dev-01897-gc8fc2a168 (2022-04-01-04:46)
Licensed under GNU GPL v2
For bug reports, read
DEPRECATED! use 'adapter speed' not 'adapter_khz'
DEPRECATED! use 'adapter driver' not 'interface'
Info : Using libusb driver
Info : clock speed 1000 kHz
Info : JTAG tap: riscv.cpu tap/device found: 0x1e200a6d (mfg: 0x536 (Nuclei System Technology Co Ltd), part: 0xe200, ver: 0x1)
Info : TAP auto0.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto1.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto2.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto3.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto4.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto5.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto6.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto7.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto8.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto9.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto10.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto11.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto12.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto13.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto14.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto15.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto16.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto17.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto18.tap does not have valid IDCODE (idcode=0x0)
Info : TAP auto19.tap does not have valid IDCODE (idcode=0x0)
Warn : Unexpected idcode after end of chain: 52 0x00000000
Warn : Unexpected idcode after end of chain: 84 0xfe000000
Error: double-check your JTAG setup (interface, speed, ...)
Error: Trying to use configured scan chain anyway...
Warn : AUTO auto0.tap - use "jtag newtap auto0 tap -irlen 2 -expected-id 0x00000000"
Error: auto0.tap: IR capture error; saw 0x0000 not 0x0001
Error: Unsupported DTM version 14. (dtmcontrol=0xffe)
全部回复 10
胡灿1373 天前 · 1 楼
那就把OpenOCD的详细log打印出来看看吧。
用两条命令在两个terminal里面来跑,make run_openocd先运行OpenOCD,要加上-D参数就会打印详细log,openOCD起来后再换个terminal运行GDB,make run_gdb,具体的命令如何运行看看Hbird SDK如何使用。
M
MicrooGRIT1374 天前 · 2 楼
回复 MicrooGRIT:
去掉这个约束还是同样的情况
我的TOP也是参考您的官方例程
M
MicrooGRIT1374 天前 · 3 楼
回复 MicrooGRIT:
本来是没有加TCK时钟约束的,后来觉得是一个时钟的输入,所以需要约束一下,我修改后再试一下,谢谢胡先生!
去掉这个约束还是同样的情况
M
MicrooGRIT1374 天前 · 4 楼
为何JTAG TCK上还接了固定时钟呢,这个是由调试器来产生的信号。
参考下蜂鸟自身的约束文件和FPGA TOP吧
胡灿1374 天前 · 5 楼
回复 MicrooGRIT:
谢谢胡先生的回复!
我的约束如下:
#------------------------------系统时钟和复位-----------------------------------
create_clock -period 20.000 -name sys_clk [get_ports sys_clk]
set_property -dict {PACKAGE_PIN R4 IOSTANDARD LVCMOS15} [get_ports sys_clk]
set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets sys_clk]
set_property -dict {PACKAGE_PIN U7 IOSTANDARD LVCMOS15} [get_ports mcu_rst]
create_clock -period 1000.000 -name jtag_clk [get_ports mcu_TCK]
set_clock_groups -asynchronous -group [get_clocks -include_generated_clocks CLK_O_8M388_PLL]
                                 -group [get_clocks -include_generated_clocks CLK_O_16M_PLL]
                                 -group [get_clocks -include_generated_clocks jtag_clk]
#-----------------------------------UART----------------------------------------
set_property -dict {PACKAGE_PIN E14 IOSTANDARD LVCMOS33} [get_ports uart0_rxd]
set_property -dict {PACKAGE_PIN D17 IOSTANDARD LVCMOS33} [get_ports uart0_txd]
#-----------------------------------MCU_JTAG----------------------------------------
set_property -dict {PACKAGE_PIN T14 IOSTANDARD LVCMOS33} [get_ports mcu_TCK]
set_property -dict {PACKAGE_PIN AA9 IOSTANDARD LVCMOS33} [get_ports mcu_TDO]
set_property -dict {PACKAGE_PIN V10 IOSTANDARD LVCMOS33} [get_ports mcu_TMS]
set_property -dict {PACKAGE_PIN N15 IOSTANDARD LVCMOS33} [get_ports mcu_TDI]
set_property KEEPER true [get_ports mcu_TMS]
set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets IOBUF_jtag_TCK/O]
#---------------------------------QSPI_FLASH----------------------------------------
set_property -dict {PACKAGE_PIN Y16 IOSTANDARD LVCMOS33} [get_ports qspi0_cs]
set_property -dict {PACKAGE_PIN AB16 IOSTANDARD LVCMOS33} [get_ports qspi0_sck]
set_property -dict {PACKAGE_PIN AA15 IOSTANDARD LVCMOS33} [get_ports qspi0_dq[0]]
set_property -dict {PACKAGE_PIN Y13 IOSTANDARD LVCMOS33} [get_ports qspi0_dq[1]]
set_property -dict {PACKAGE_PIN AA13 IOSTANDARD LVCMOS33} [get_ports qspi0_dq[2]]
set_property -dict {PACKAGE_PIN W11 IOSTANDARD LVCMOS33} [get_ports qspi0_dq[3]]
M
MicrooGRIT1374 天前 · 6 楼
这个看上去是JTAG除了检测出蜂鸟的内核外,还在往后扫描,读到的东西又不对。
检测一下硬件架构和管脚约束吧
谢谢胡先生的回复!
我的约束如下:
胡灿1374 天前 · 7 楼
检测一下硬件架构和管脚约束吧
M
MicrooGRIT1375 天前 · 8 楼
回复 wonder:
可以参考: https://www.riscv-mcu.com/community-topic-id-1014.html
谢谢您的回复!
我之前看过这个帖子了,也跟着这个做了,还是没效果
w
wonder1375 天前 · 9 楼
M
MicrooGRIT1376 天前 · 10 楼
已修改为内部ROM启动,并注释了*.cfg文件中的Flash相关代码
