论坛/开源蜂鸟E203/求助 调试器连不上目标板
求助 调试器连不上目标板
开源蜂鸟E203 作者 陈周鹏 发布于 2024-10-14 13:53(766 天前) 6596 浏览
在linux使用HUMMINGGBIRD Debugger Kit V2 连接目标板上e203提示出错如下:
(hbirdenv) root@linuxczp:/home/nuclei-hbird/hbird-sdk/application/baremetal/helloworld# make upload SOC=hbirdv2 BOARD=ddr200t CORE=e203 DOWNLOAD=ilm
Download and run helloworld.elf
riscv64-unknown-elf-gdb helloworld.elf -ex “set remotetimeout 240” \
-ex “target remote | openocd -c \”gdb_port pipe; log_output openocd.log\” -f ../../../SoC/hbirdv2/Board/ddr200t/openocd_hbirdv2.cfg” \
—batch -ex “monitor reset halt” -ex “load” -ex “monitor resume” -ex “quit”
Open On-Chip Debugger 0.11.0+dev-02400-g1dac85c02 (2024-06-26-07:32)
Licensed under GNU GPL v2
For bug reports, read
Remote communication error. Target disconnected.: Connection reset by peer.
“monitor” command not supported by this target.
You can’t do that when your target is `exec’
找不到目标板上的器件,底层跟踪如下各管脚时序如下:
请问一下大神们,正确的时序应是怎么样的?忘指导一下,不甚感激!
各管脚时序图
全部回复 10
陈
陈周鹏765 天前 · 1 楼
回复 dongyong:
是的 是这个问题 探测flash失败了. Nuclei SPI controller version 0x00000000, all 0
那你手动改下这个配置文件 openocd -c "gdb_port 3333" -f ../../../SoC/hbirdv2/Board/ddr200t/openocd_hbirdv2.cfg
找到下面flash的地方 注释掉试试
if { [ info exists NOFLASH ] } {
    puts "No flash bank is set"
} else {
    set _FLASHNAME $_CHIPNAME.flash
    if { $BDTYPE eq "rvstar" } {
        flash bank $_FLASHNAME gd32vf103 0x08000000 0 0 0 $_TARGETHARTNAME
    } else {
        flash bank $_FLASHNAME nuspi 0x20000000 0 0 0 $_TARGETHARTNAME
谢谢 dongyong
HummingBird SDK Build Time: Sep 27 2024, 06:44:17
Download Mode: FLASHXIP
CPU Frequency 16055664 Hz
MISA: 0x40001105
MISA: RV32IMAC
0: c Hello World From RISC-V Processor!
1: c Hello World From RISC-V Processor!
2: c Hello World From RISC-V Processor!
3: c Hello World From RISC-V Processor!
4: c Hello World From RISC-V Processor!
5: c Hello World From RISC-V Processor!
6: c Hello World From RISC-V Processor!
7: c Hello World From RISC-V Processor!
8: c Hello World From RISC-V Processor!
9: c Hello World From RISC-V Processor!
10: c Hello World From RISC-V Processor!
11: c Hello World From RISC-V Processor!
12: c Hello World From RISC-V Processor!
13: c Hello World From RISC-V Processor!
14: c Hello World From RISC-V Processor!
15: c Hello World From RISC-V Processor!
16: c Hello World From RISC-V Processor!
17: c Hello World From RISC-V Processor!
18: c Hello World From RISC-V Processor!
19: c Hello World From RISC-V Processor!
串口接收打印正确了!
陈
陈周鹏766 天前 · 2 楼
回复 dongyong:
找到下面flash的地方 注释掉试试
} else {
    } else {
修改出现如下内容
(hbirdenv) root@linuxczp:/home/nuclei-hbird/hbird-sdk/application/baremetal/helloworld# make SOC=hbirdv2 BOARD=ddr200t CORE=e203 DOWNLOAD=ilm run_openocd
Start openocd server
DEPRECATED! use 'adapter speed' not 'adapter_khz'
DEPRECATED! use 'adapter driver' not 'interface'
DEPRECATED! use 'ftdi vid_pid' not 'ftdi_vid_pid'
DEPRECATED! use 'ftdi oscan1_mode' not 'ftdi_oscan1_mode'
DEPRECATED! use 'ftdi layout_init' not 'ftdi_layout_init'
DEPRECATED! use 'ftdi layout_signal' not 'ftdi_layout_signal'
Info : Using libusb driver
Info : clock speed 1000 kHz
Info : JTAG tap: riscv.cpu tap/device found: 0x1e200a6d (mfg: 0x536 (Nuclei System Technology Co Ltd), part: 0xe200, ver: 0x1)
Info : Examined RISCV core; XLEN=32, misa=0x40001105
[riscv.cpu] Target successfully examined.
Info : [riscv.cpu] Found 0 triggers
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Error: TDO seems to be stuck high.
d
dongyong766 天前 · 3 楼
回复 陈周鹏:
因为我板上没有SPI FLASH,会是这个问题吗?其他也没什么好改的。
找到下面flash的地方 注释掉试试
} else {
    } else {
陈
陈周鹏766 天前 · 4 楼
回复 dongyong:
Error: timeout
Error: auto_probe failed
这里看起来你rtl有问题,是不是改动了什么
d
dongyong766 天前 · 5 楼
回复 陈周鹏:
Info : Valid NUSPI on device Nuclei SoC SPI Flash at address 0x20000000 with spictrl regbase at 0x10014000
Info : Nuclei SPI controller version 0x00000000
Error: timeout
make: *** [../../../Build/Makefile.rules:110: run_openocd] Error 1
是这个错误,超时!
Error: timeout
陈
陈周鹏766 天前 · 6 楼
回复 dongyong:
make SOC=hbirdv2 BOARD=ddr200t CORE=e203 DOWNLOAD=ilm run_openocd  先看看openocd的打印输出
Error: timeout
是这个错误,超时!
d
dongyong766 天前 · 7 楼
回复 陈周鹏:
(hbirdenv) root@linuxczp:/home/nuclei-hbird/hbird-sdk/application/baremetal/helloworld# make run_ocd
make: *** No rule to make target 'run_ocd'. Stop.
这个好像是不能运行,驱动应是安装了
Bus 001 Device 002: ID 0403:6010 Future Technology Devices International, Ltd FT2232C/D/H Dual UART/FIFO IC
串口也可以用的。
sudo vi /etc/udev/rules.d/99-openocd.rules
// Use vi command to edit the file, and add the following lines
SUBSYSTEM=="usb", ATTR{idVendor}=="0403",
ATTR{idProduct}=="6010", MODE="664", GROUP="plugdev"
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403",
ATTRS{idProduct}=="6010", MODE="664", GROUP="plugdev"
这个文件也创建了
(hbirdenv) root@linuxczp:/home/nuclei-hbird/hbird-sdk/application/baremetal/helloworld# groups
root plugdev
这个也是正确的,
接线应是正确的,底层跟踪TCK,TDO,TDI,TMS波形也有!
d
dongyong766 天前 · 8 楼
回复 陈周鹏:
这个好像是不能运行,驱动应是安装了
串口也可以用的。
这个文件也创建了
root plugdev
这个也是正确的,
写错了。 是 make run_openocd
陈
陈周鹏766 天前 · 9 楼
回复 dongyong:
make run_ocd 看看log 有无报错,设备管理器确认下是不是没有装驱动 或者接线
这个好像是不能运行,驱动应是安装了
串口也可以用的。
这个文件也创建了
root plugdev
这个也是正确的,
d
dongyong766 天前 · 10 楼
