论坛/开源蜂鸟E203/蜂鸟E203与电脑实现UART通信实现代码并实现上位机控制代码分享
开源蜂鸟E203 作者 发布于 2021-07-25 22:16(1943 天前) 7285 浏览
        大家好,我们是这是一件好事队,队伍编号为CICC1859,这里想和大家分享一下蜂鸟E203与电脑的UART通信代码,并通过UART实现上位机控制。
电脑端UART代码:
#include "stdio.h"
HANDLE GetSerialPortHandle(const char *name) {
    printf("Opening %s...\n", name);
    fflush(stdout);
    HANDLE hCom = CreateFileA(name,
                       GENERIC_READ | GENERIC_WRITE,
                       0,
                       NULL,
                       OPEN_EXISTING,
                       FILE_ATTRIBUTE_NORMAL,
                       NULL);
    if (hCom == INVALID_HANDLE_VALUE) {
        printf("Open COM failed!\n");
        fflush(stdout);
        return NULL;
    printf("Configuring Timeout...\n");
    fflush(stdout);
    COMMTIMEOUTS TimeOuts;
    TimeOuts.ReadIntervalTimeout = 0;
    TimeOuts.ReadTotalTimeoutMultiplier = 0;
    TimeOuts.ReadTotalTimeoutConstant = 0;
    TimeOuts.WriteTotalTimeoutMultiplier = 1;
    TimeOuts.WriteTotalTimeoutConstant = 1;
    SetCommTimeouts(hCom, &TimeOuts);
    printf("Configuring serial port...\n");
    fflush(stdout);
    DCB dcb;
    GetCommState(hCom, &dcb);
    dcb.BaudRate = 115200;
    dcb.ByteSize = 8;
    dcb.Parity = NOPARITY;
    dcb.StopBits = ONESTOPBIT;
    SetCommState(hCom, &dcb);
    return hCom;
void CloseSerialPortHandle(HANDLE handle) {
    CloseHandle(handle);
int32_t ReadSerialPort(HANDLE hCom, uint8_t *pMessage, size_t length) {
    WINBOOL bReadStat;
    DWORD wCount;
    bReadStat = ReadFile(hCom, pMessage, length, &wCount, NULL);
    if (!bReadStat)
        printf("Failed to read serial port\n");
        fflush(stdout);
    return bReadStat;
int32_t WriteSerialPort(HANDLE hCom, const uint8_t *pMessage, size_t length) {
    WINBOOL bReadStat;
    DWORD wCount;
    bReadStat = WriteFile(hCom, pMessage, length, &wCount, NULL);
    if (!bReadStat)
        fflush(stdout);
    return bReadStat;
        代码主要包含开启UART:GetSerialPortHandle(),关闭UART:CloseSerialPortHandle()以及UART读写WriteSerialPort()ReadSerialPort()
        蜂鸟E203 UART配置采用官方代码:
int32_t uart_init(UART_TypeDef *uart, uint32_t baudrate)
    if (__RARELY(uart == NULL)) {
        return -1;
    unsigned int uart_div = SystemCoreClock / baudrate - 1;
    uart->LCR = 0x80;
    uart->DLM = (uart_div >> 8) & 0xFF;
    uart->DLL = uart_div        & 0xFF;
    uart->FCR = 0xC6;
    uart->LCR = 0x03;
    return 0;
int32_t uart_config_stopbit(UART_TypeDef *uart, UART_STOP_BIT stopbit)
        return -1;
    uart->LCR &= 0xFFFFFFFB;
    uart->LCR |= (stopbit << 2);
    return 0;
int32_t uart_enable_paritybit(UART_TypeDef *uart)
        return -1;
    uart->LCR |= 0x8;
    return 0;
int32_t uart_disable_paritybit(UART_TypeDef *uart)
        return -1;
    uart->LCR &= 0xFFFFFFF7;
    return 0;
int32_t uart_set_parity(UART_TypeDef *uart, UART_PARITY_BIT paritybit)
        return -1;
    uart->LCR &= 0xFFFFFFCF;
    uart->LCR |= (paritybit << 4);
    return 0;
int32_t uart_write(UART_TypeDef *uart, uint8_t val)
        return -1;
#ifndef SIMULATION_SPIKE
#ifndef SIMULATION_XLSPIKE
    while ((uart->LSR & 0x20) == 0);
#endif
    uart->THR = val;
#else
    extern void htif_putc(char ch);
    htif_putc(val);
#endif
    return 0;
uint8_t uart_read(UART_TypeDef *uart)
    uint32_t reg;
        return -1;
    while ((uart->LSR & 0x1) == 0);
    reg = uart->RBR;
    return (uint8_t)(reg & 0xFF);
int32_t uart_enable_tx_empt_int(UART_TypeDef *uart)
        return -1;
    uart->IER |= 0x2;
    return 0;
int32_t uart_disable_tx_empt_int(UART_TypeDef *uart)
        return -1;
    uart->IER &= 0xFFFFFFFD;
    return 0;
int32_t uart_set_rx_th(UART_TypeDef *uart, uint8_t th)
        return -1;
    if(th > 3) {
       th = 3;
    uart->FCR &= 0xFFFFFF3F;
    uart->FCR |= (th << 6);
    return 0;
int32_t uart_enable_rx_th_int(UART_TypeDef *uart)
        return -1;
    uart->IER |= 0x1;
    return 0;
int32_t uart_disable_rx_th_int(UART_TypeDef *uart)
        return -1;
    uart->IER &= 0xFFFFFFFE;
    return 0;
int32_t uart_enable_rx_err_int(UART_TypeDef *uart)
        return -1;
    uart->IER |= 0x4;
    return 0;
int32_t uart_disable_rx_err_int(UART_TypeDef *uart)
        return -1;
    uart->IER &= 0xFFFFFFFB;
    return 0;
int32_t uart_get_int_status(UART_TypeDef *uart)
        return -1;
    return uart->IIR;
int32_t uart_get_status(UART_TypeDef *uart)
        return -1;
    return uart->LSR;
        由此配置双方UART,并在双方主函数中调用写入读取函数即可完成电脑与蜂鸟E203的通信。下面为实测图:
        双方通过UART完成了Kyber(本作品设计)的通信过程。
