Nuclei 用户模式如何切换回机器模式
N级别处理器内核从User Mode切换到Machine Mode只能通过异常、响应中断或者NMI的方式发生:
响应异常进入异常处理模式。请参见第3.4节了解其详情。
注意:软件可以通过调用ecall指令强行进入ecall异常处理函数。
响应中断进入中断处理模式。请参见第5.6节了解其详情。
响应NMI进入NMI处理模式。请参见第4.3节了解其详情。
根据说明,进入用户模式后,Led()执行ecall命令就会进入异常中断ECALL_Exception_Handler,这时候是在M模式了吗?代码怎么能从异常中断回到主函数继续执行while循环里的语句呢?
/** @addtogroup CM32M4xxR_StdPeriph_Examples
#define MACHINE_MODE_STACK_SIZE 0x400
static uint8_t sMachineModeStack[MACHINE_MODE_STACK_SIZE] = {0};
//Configure test_array Acess Permission on PMP
void PMP_Config() {
PMP_Region_InitTypeDef pmp_init;
pmp_init.Number = PMP_REGION_NUMBER0;
pmp_init.Enable = PMP_REGION_ENABLE; // Enable Configuration
pmp_init.Lock = PMP_REGION_UNLOCK; //
pmp_init.BaseAddress = 0; //
pmp_init.Size = PMP_REGION_SIZE_4GB; //Setting array size
pmp_init.AddressMatching = PMP_ADDRESS_MATCHING_NAPOT; //Setting PMP Size to NAPOT mode -> 2^n
pmp_init.AccessPermission = PMP_ACCESS_RWX; //Setting array permission is Read Only
PMP_ConfigRegion(&pmp_init);
sPMP_Region_InitTypeDef spmp_init;
spmp_init.Number = SPMP_REGION_NUMBER0;
spmp_init.Enable = SPMP_REGION_ENABLE;
spmp_init.Lock = SPMP_REGION_UNLOCK;
spmp_init.BaseAddress = 0;
spmp_init.Size = SPMP_REGION_SIZE_4GB;
spmp_init.AddressMatching = SPMP_ADDRESS_MATCHING_NAPOT;
spmp_init.UserMode = SPMP_USERMODE_RESET;
spmp_init.AccessPermission = SPMP_ACCESS_RWX;
sPMP_ConfigRegion(&spmp_init);
* @brief Jump User Mode
void JumpUserMode(uint32_t func)
__RV_CSR_WRITE(CSR_MSCRATCH, sMachineModeStack + MACHINE_MODE_STACK_SIZE);
__RV_CSR_CLEAR(CSR_MSTATUS, MSTATUS_MPP);
__RV_CSR_WRITE(CSR_MEPC, func);
__ASM volatile ( "mret ");
void ECALL_Exception_Handler(unsigned long mcause,unsigned long sp)
uint32_t saved_regs = sp;
uint32_t mepc = ((uint32_t *)saved_regs)[12];
printf("ECALL Exception Trigger\r\n");
((uint32_t *)saved_regs)[12] = mepc + 4;
* @brief User Mode Application
void Led()
LedInit(LED2_PORT, LED2_PIN);
__ECALL();
* @brief Main function
int main(void) {
/* System Clocks Configuration */
PMP_Config();
Exception_Register_EXC(UmodeEcall_EXCn, (unsigned long)ECALL_Exception_Handler);
JumpUserMode((uint32_t)Led);
while (1) {
LedBlink(LED2_PORT, LED2_PIN);
delay_ms(1000);
d
dekira869 天前 ·
1 楼
回复 yuxin:
但是用户模式下是不能访问mstatus和使用mret指令的,会引发非法指令异常
在user mode,Led()调用Ecall会产生异常,然后进入machine mode
异常会从MTVEC定义的PC地址开始执行。先保存现场,然后调用你定义的ECALL_Exception_Handler函数,这个函数执行完之后继续执行MTVEC代码,回现场,最后调用mret返回user mode,应该是这个过程。
异常处理函数实际上不是你定义的ECALL_Exception_Handler函数,而是一个其他的函数,这个函数的入口地址被指定到MTVEC寄存器,你定义的ECALL_Exception_Handler函数只是在这个函数中调用了一次而已。
版块CM32M433R MCU
回复3
浏览5491
发布2024-07-02 14:16
本版热门
关于如何创建一个浮点立即数0 回复
